Old 10-19-2009, 02:41 PM   #1
Question patio door installation question
Does the patio door sit on the subfloor or on top of the finished floor?
I am asking because the previous owners installed it on top of the finished floor, which was really just an extension of the deck, so the patio door was installed on top of a deck board.
I have since built a new deck, lower than the level of the 3-seasons room, and have removed the rotted deck board that the door was installed on.
So the question is, do I install a new deck board to finish the floor in the 3 seasons room, and the patio door on top of that?
OR
Do I install the patio door on top of the subfloor and the install the deck board floor piece to finish up the installation?
On deck bord?
On subfloor?
old door
rough opening, still needs to be framed in, you can see where I removed the deck board, exposing the subflooring.
gintaras is offline   Reply With Quote
Old 10-19-2009, 11:52 PM   #2
got my answer after looking at the bottom of the new Pella 450 series.. the deck board used as flooring in the patio will butt up against the bottom of the door nicely, giving it a nice finished look instead of having the door protrude above the flooring.
More On This Topic
The rafters of a patio overhead serve two main purposes. They're meant to firmly hold the overhead in place, and they're meant to add decoration to your patio. Patio overhead rafters are moderately easy to assemble and install. Read More »
Most woods are categorized as either hardwood or softwood, depending on their density and weight. Softwoods grow faster than hardwoods and are softer, easier to work and cheaper, making them a versatile choice for many carpentry projects. Hardwoods are... Read More »
Ok, so, now all we have left to do, is get our bottom board in. And, what we'll do is, we'll just take this whole door off, see if that will give us enough room, for this to slide in. (Cough) Excuse me. Now, put our hinges back on. And, there we go. OK... Read More »
Arranging your patio furniture in an eye-pleasing as well as functional manner can really add comfort to your yard. With some simple guidelines, you can spruce up your patio and make it look inviting and welcoming, while keeping function in the forefront... Read More »
Weather proofing a deck can save a homeowner thousands of dollars in repairs and deck replacements. Making a deck weather proof should be done as soon as the deck is built, or as soon as it comes into your possession. Keep it weather proofed to ensure... Read More »
Pouring Patio Slab and Post Footings Question average_male Building & Construction 17 09-27-2009 03:44 PM
Patio Roof Question? homelocation2 Roofing 3 08-11-2009 11:31 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 09:51 AM
patio cover/roof footing question toolbeltmamma Building & Construction 7 05-21-2008 09:20 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
