Patio Cracked & Sinking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2011, 06:05 PM   #1
I purchased my home 2 years ago and since have been thinking about what I can do with my patio. The patio is 16' x 3' and 18 inches high. The patio is cracked about 3/4 of the way up and all the way across the patio. Additionally, the patio appears to have sunk toward the house. I though of possibly building a deck over the patio. However, I do not know if this is the right decision. I also have though of either hiring someone or jackhammering the patio out myself? Can I even do that considering it appears the patio is attached to the house? Is it ok to just build a deck on top of the patio and be done with it? I am a pretty handy individual and have done a significant amount of DIY work. However, I have not tackled a project quite like this before and am not familiar with masonary/concrete work. Any ideas on building the deck on the patio, removing the patio, re-building the patio, reparing the patio (if possible) are greatly appreciated. Attached are some photos.
Patio Cracked & Sinking-1.jpg   Patio Cracked & Sinking-2.jpg   Patio Cracked & Sinking-3.jpg
silvabul is offline   Reply With Quote
Old 05-03-2011, 09:44 PM   #2
Stay-at-home GC
Use a level to confirm if it has settled toward the house. It should slope AWAY from the house at 1/4" per foot or better.
If it slopes into the house you should remove it. Building a deck over it will just allow water to rot out the framing over time.
Also looks like it was repaired once before.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-03-2011, 10:46 PM   #3
Civil Engineer
Rewards Points: 4,944
I can't tell from the photo, but it looks like you may have parging over block rather than a solid concrete patio. As previously noted, you need to check the entire patio with a level. If it is in fact sinking, this would indicate a poor foundation, and building a deck on top of it would be a bad idea.
Daniel Holzman is online now   Reply With Quote
Old 05-04-2011, 09:53 AM   #4
Rewards Points: 4,800
looks as if someone's already repaired that cold joint above the steps,,, grab up a level & ck for sinking,,, if you don't have a level, pour some water on the deck & watch where it runs polymer-modified/cement/fine aggregate can restore the necessary slope w/o adding too much dead weight.
as you can plainly see, mortar is NOT the way to cover any joint that 'moves',,, the best repair's to seal it w/backer rod & jnt sealant,,, had that been done originally, you wouldn't have this problem now however builders can't see our houses from their house so what the hell
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
Sinking concrete patio canadaclub Building & Construction 9 07-30-2009 07:56 AM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 01:41 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
