-   -   Patio Cover or not? (http://www.diychatroom.com/f19/patio-cover-not-141946/)
greentrees 04-29-2012 02:26 AM
Patio Cover or not?
4 Attachment(s)
I removed my deck from the backyard and will replace it with cement. I was curious if I should install a patio cover.
The backyard is 24 feet deep by 53 feet wide. The tree is in front of the half cicle window. When looking at the photo with the windows, I will lay cement from the backyard door all the way to the right (aligning with the side of the house).
The backyard faces north so the sun is straight above during summer.
Since the backyard is not very deep, would a patio cover like a lattice, or any other type, be appealing?
It might provide some privacy from the neighbor in the back, since the bush just barely covers their window. They have a patio cover, but it extends really close to the fence, so it doesn't look very appealing.
joecaption 04-29-2012 12:39 PM
With a tile roof and stucco siding I'd go with a free standing pergala.
If there concerns about privacy there's no reason one side could not have a few 2 X 4's run horizontal and just attach some vinyl lattis to them.
greentrees 04-29-2012 02:17 PM
3 Attachment(s)
Nice idea. I wasn't clear on what the difference between a vinyl or aluminum pergola, or whether they are the same.
Since I will be laying cement, I guess I could lay the cement first and than design the pergola later, by just installing posts right on top of the cement?
I attached a few photos of what I think you were mentioning about the siding. It could be solid or a lattice.
joecaption 04-29-2012 02:43 PM
The differance is one's aluminum and ones made of vinyl,
Not cheap but if built right should last a life time with little more then a cleaning once in a while.
A soild fence wall would block the air flow so keep that in mind.
greentrees 05-01-2012 10:33 PM
Curious if I can first lay the cement and than worry about the pergola design later. I wasn't sure if the brackets drill right down into the cement or are they sunk into the cement prior to pouring.
GeorgeEaton 01-20-2014 12:35 AM
Well i think it's a good idea. According to your space as discussed it is enough space to add patio cover. There are new versions of patio cover available in market.
Msradell 01-21-2014 10:31 PM
There are also several varieties of retractable patio covers available that rollup and rollout as required. They can be controlled either manually or electrically. An advantage of them would be that you could have full sun on the patio if you wanted it.
