Patio Awning Design Check - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 06:26 PM   #1
Patio awning design check
I am in the process of designing an awning for our patio. The patio is a 12'x24' concrete pad. The awning will be attached to the house (brackets on a ledger board) with four 4x4 posts at the other end.
Using www.awc.org (calculator for rafters) I determined that I should use at least 2x6, 16oc, #2 (non-incised) Dougals Fir to cover the 12' span between the ledger and the posts. This is based upon a 20psf snow-load (which is actually more than the 10psf spec'd for my location), 10psf dead load, and L/240 deflection. The "inch-per-foot" rule implies I would need an 2x8 header.
But I plan to use corrugated fibreglass or other synthetic panels for the roof so the dead load would be significantly less than with standard construction.
So I'm wondering if this is overkill or seems right. I'd appreciate your feedback before I proceed.
I've attached a shot of my design from Sketchup.
RodBarnes is offline   Reply With Quote
Old 07-27-2012, 05:20 PM   #2
Rewards Points: 502
The 2x6s spanning from the house wall to the main bearers across the posts would be OK (2x8s would be unnecessary).
Your main problems will be fixing the main bearers to the posts, and then the joists to the main bearers, allowing for wind uplift, as these roofs are very light. Simpson do special fixings for this
tony.g is offline   Reply With Quote
Old 07-27-2012, 05:31 PM   #3
I plan on using hangers on both ends of the joists screwed into the ledger and main bearers. Likewise, I plan to use similar connectors with screws to attach main bearers to posts. Posts will be bolted/screwed into post brackets which are already embedded in concrete when I had it poured. Screws will attach roof panels to strips across joists.
Old 07-27-2012, 07:26 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
Rod,
sounds like you've put a lot of thought into your design. Wind loads need to be addressed as you are building basically a sail. Your location determines wind loads. Where are you located?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-28-2012, 06:51 PM   #5
Located in NW Oregon. We don't get a lot of significant wind. Maybe a windstorm one or two times a year that gust to 40+. Rarely more -- such as the Columbus Day storm of 1962. I was a kid then and remember it but that is the rare case where even house roofs had problems. There are plenty of awnings around similar to what I want to build and they've all survived.
cutting out foundation wall for patio door lfunk11 Building & Construction 9 03-27-2011 10:55 PM
Patio Cover Design Questions MrBill Building & Construction 3 06-09-2009 11:34 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 02:41 PM
Replacing patio - Relocate downspout slvrbullet98 Landscaping & Lawn Care 2 05-08-2009 09:30 AM
New cememt patio stained by wet leaves Bhoward Landscaping & Lawn Care 7 12-03-2008 12:35 PM
