Patching Up A Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2008, 09:33 AM   #1
wfischer's Avatar
Patching up a concrete wall
I'm getting ready to paint, but first I need to fill in these gouges. What product would I use for this?
wfischer is offline   Reply With Quote
Old 03-11-2008, 11:00 AM   #2
so-elitecrete
Rewards Points: 150
just clean the holes,,,
w/wire brush or rotary drill w/brush,,, blow out dust or wash w/clean wtr,,, patch while still damp,,, we'd use sika avail at h/dlowe'sacehdweetc,,, imo, i haven't found a suitable paint that'll ' hold ' on conc, tho,,, coatings, yes, but paint, no.
just my $.03
so-elitecrete is offline   Reply With Quote
Old 03-11-2008, 05:15 PM   #3
CT Builder
preperations as above stated...
suggest this for patching the holes...
http://www.quikrete.com/ProductLines...StopCement.asp
suggest this as a covering...
http://www.ugl.com/drylokMasonry/mas...roofer/oil.php
it even comes in colors!!!
-Daryl
Daryl is offline   Reply With Quote
Old 03-11-2008, 05:49 PM   #4
so-elitecrete
Rewards Points: 150
under the right conditions,
imo, ugl's as good as thoroseal & drilok,,, a water-permeable coating's still best, tho.
just my $0.03.
Old 03-11-2008, 07:04 PM   #5
concretemasonry's Avatar
Rewards Points: 2,566
I all depends on what kind of a job you want.
DryLok and UGL are DIY products.
Thoro products has a complete line designed for commercial and industrial construction and concrete renovation/repairs. The basic material is Thoroseal that is also used for residential. There also is a second finish coat, Thorosheen, that is a 100% acrylic material for more finished surface that has several different sheens and many colors. There is also Thoroglaze that is more of a protective/pollution protection.
You rarely see them in residential construction because of the intended use, but they do work and are more costly than the "big box" products.
concretemasonry is offline   Reply With Quote
Old 03-13-2008, 03:13 PM   #6
so-elitecrete
Rewards Points: 150
having used all these mtls,,,
for many years, i wouldn't on my own home altho the previous owner painted 1 below-grade wall w/(ugl-dri-lock-???),,, it now must be scaled off &, depending on what i find, either repair'd or left alone,,, if i need do anything, it'll be zypex.
we used thoroseal at rutgers-newark & it work'd great but that was on rooftop structures,,, imn-s-hfo, h/dlowe'sacehdwe don't carry pro grade mtls but h/o & diy grades only in these items.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Best way to handle this - furring out concrete freeze wall J187 Building & Construction 10 05-14-2007 06:17 PM
Concrete cement wall leaks and paint BobFar Building & Construction 7 04-16-2007 06:22 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
