Patching unfinished basement ceiling? Pictures included
The first hole I would patch by cutting plywood longer that the hole, screw
it into the the 2x and then silicone gaps or use the canned foam. The second hole could be fixed the same way or just using the canned foam. That is unless you want to try to find flashing that could be trimmed to fit.
My constant project is my home which was built in 1947. I have remodeled almost all of it and am in the process of finishing off a 1000 square foot addition. Lars Construction got me up to drywall and I am doing the rest. You can see many galleries of it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. under Galleries and then House.
