Patching Stucco To Match Existing Exterior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 10:49 AM   #1
Patching (?Tyrolean, Rough Cast, pebbledash, stucco?)to match existing exterior walls
Hello,
I am removing about 15 boards from the exterior of the house that run the height of the walls. The only problem is that these board were set into the stucco.
I will be painting the exterior of the house in about 3 weeks, so I would like to figure out how I will be patching these areas, in order to get it to match the existing stucco.
here are a few pictures of the issue:
Thank you.
bokeh is offline   Reply With Quote
Old 05-05-2011, 12:26 PM   #2
Rewards Points: 582
Looks a bit like Tyrolean which is put on with a hand operated machine.
stuart45 is offline   Reply With Quote
Old 05-06-2011, 07:47 AM   #3
Attachment 32767
Thanks for pointing me in the right direction. Most of the info I find on Tyrolean is in the UK.
I found a place online where I can order a flicker gun.
http://www.bontool.com/product1.asp?P=B15-144
Reading about Tyrolean brought me to pebbledash & rough cast which also look similar. are there other names the material might go by so that I can try to find it locally? Or can I get the same results mixing things together
What I need to do is blend this patching before I paint the exterior in a few weeks. Would I just apply the new texture over the existing material after removing the boards?
I am thinking I may have to break away some of the edging from the existing texture. it seems that it will definitely stand out, its raised and flat where the texture came in contact with the boards. I'm guessing they put the boards in when the texture was wet or something. It looks like material was squished out from behind the boards to seat them in the walls.
Old 05-06-2011, 01:12 PM   #4
Pebbledash can look a bit like Tyrolean if it's painted.
Here's a thread from another forum which might help.
http://www.diynot.com/forums/viewtop...495265#1495265
devonman is offline   Reply With Quote
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 08:44 PM
New Condensing Unit to Match Existing Air Handler? sweaty HVAC 5 03-04-2009 12:37 PM
Stucco Fins vs. Nail Fins on Stucco House xquercus General DIY Discussions 5 01-25-2009 04:44 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Covering stucco BigJimmy Building & Construction 1 05-23-2008 11:19 PM
