Patching Small Holes In Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 05:22 PM   #1
Rewards Points: 1,062
patching small holes in concrete
what is the main difference between using the expensive patcher mix (~$15) vs. regular concrete mix ? holes like a ft by a ft.
Old 07-22-2008, 05:24 PM   #2
Rewards Points: 1,666
how deep is the hole?
bob22 is offline   Reply With Quote
Old 07-22-2008, 05:25 PM   #3
deeper than the concrete. maybe a foot or so. will fill with gravel up to the level where the concrete goes.
Old 07-22-2008, 05:32 PM   #4
I'm a bit confused. You've a 1' x 1' wide hole. The depth is "deeper than the concrete". What concrete? How thick is this concrete? When patched, what use will this patched area be for (support for building above, etc...)?
Old 07-22-2008, 05:42 PM   #5
i wanted to move a sewer pipe by a foot. broke the concrete, cut wire mash, tore foam, dug out the gravel and dirt, got to the pipe, adjusted it.
Old 07-23-2008, 06:31 AM   #6
those pre-bagg'd conc mixes yield .6cf,,, 2 of 'em will do it,,, then again, can't see your house from my house
yesitsconcrete is offline   Reply With Quote
Old 07-23-2008, 07:48 AM   #7
but my question was whether i should use regular concrete (cheap) or patcher mortar (expensive and advertised for this kind of applications) ?
Old 07-23-2008, 09:21 AM   #8
my answer's the same,,, reg bagg'd conc mix avail at any apron store,,, uner $15 for both
Old 07-23-2008, 11:50 AM   #9
thanks sir.
Old 07-23-2008, 12:37 PM   #10
i prefer ' sire ' or ' your majesty ' termite's the ' crown prince '
small cracks in PT sole plates on concrete amakarevic Building & Construction 14 07-23-2008 01:48 PM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 12:41 PM
forming shallow holes in surface of wet concrete mx13 Building & Construction 1 04-25-2008 09:59 PM
forming holes in surface of wet concrete mx13 Landscaping & Lawn Care 1 04-25-2008 05:06 PM
correcting slightly uneven small concrete surface amakarevic Building & Construction 5 01-16-2008 07:38 PM
