Patching Plaster Skim Coat - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2008, 09:43 AM   #1
patching plaster skim coat
I had to cut a hole in my basement ceiling for a plumbing repair. The hole is rectangular and roughly 2ft square. The ceiling is blue-board with a skim coat of textured plaster. The plumber said it looks like it was done with a skip-trowel. The texture is very rough, almost like the plaster was just quickly applied and allowed to dry without smoothing.
Obviously, the BEST way to repair this is with real plaster. Since I have no experience working with plaster, and everyone I have talked to recommends staying away from it if you are not a pro, what else can I do? Are there any pre-mixed products suitable for this project? I'm thinking that regular joint-compound may be too soft.
thomase is offline   Reply With Quote
Old 06-30-2008, 11:21 AM   #2
Registered User
Termite's Avatar
I don't see a reason you couldn't use joint compound. You might need to add a tiny bit of water to make it more workable.
Old 06-30-2008, 11:28 AM   #3
Ok, I guess I can practice the texture on a spare piece of blueboard. Any tips for producing a skip-trowel texture?
How to Skim Coat Walls LeahMia1995 Remodeling 2 03-07-2008 01:25 PM
Cement, plaster, paint - ceiling: "spray skim coat"? BradG Painting 1 11-18-2007 06:06 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Need help please asap...patching plaster pics attached mood Building & Construction 2 07-30-2005 10:06 PM
