Patching Cracks In Concrete Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 10:48 AM   #1
patching cracks in concrete driveway
can i use cold patch asphalt to fill in the cracks in my concrete driveway, i have tryed a lot of fillers and they all crack and crumble after the winter.
cookieman is offline   Reply With Quote
Old 05-19-2011, 11:25 AM   #2
Hey Cookieman,
Yah I have had the same problem concrete driveways. Most crack fillers aren't made to stand that kind of traffic and weather change. What I used for small cracks is a construction sealant. I never had cracks bigger than a quarter inch, but for the normal small cracks it worked great. I used Sika brand because it is flexible and matches the color of the concrete drive way. I wouldn't use anything meant for a asphalt driveway. Even though it might work it wont look pretty.-Gregg
gotogregg is offline   Reply With Quote
The Following User Says Thank You to gotogregg For This Useful Post:
cookieman (05-27-2011)
Old 05-19-2011, 11:43 AM   #3
Rewards Points: 5,336
As Gregg said, the Sika products are very good for this issue. If the cracks are deep and/or wide, use a backer rod to shove in the crack to limit the anount of material you have to use. The backer rod comes in widths of 1/4" -3/4" so you can find what you need.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 08:08 AM
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 08:07 AM
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
spider cracks in garage foundation and concrete ramp up into garage alhippy Building & Construction 1 08-29-2010 10:48 AM
Tile on concrete floor....with 1/8th inch cracks.. tigerbalm2424 Flooring 23 06-21-2008 09:01 PM
