Patch Cement Block Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 10:35 PM   #1
Patch cement block wall?
Looking for advice on patching a cement block retaining wall. Crumbling in a few places. I was hoping to be able to build a form and fill in the holes, or maybe knock out the broken pieces and cut a new block to size as a replacement.
Anyone have some suggestions?
k.kuenn is offline   Reply With Quote
Old 05-27-2009, 07:25 AM   #2
That just does not look right. Is there a footer under that wall??? Other problems with the wall??
Old 05-27-2009, 09:08 AM   #3
actually that should NOT be attach'd, contact, or otherwise adjoin the steps,,, guessin' movement's caus'd spalling,,, a sealant's the best choice applied over clos'd cell backer rod of the appropriate dimension
yesitsconcrete is offline   Reply With Quote
Old 05-30-2009, 11:52 AM   #4
Thanks! One last question...before I put the closed backer rod at the bottom do I need to fill behind it with anything? The gaps are pretty deep.
Old 05-31-2009, 08:40 AM   #5
nope, nuttin,,, HOWEVER, make certain the backer rod's oversize to the extent it stays in place ( compression ),,, that way your sealant'll adhere to the sides of this ' joint ' & it'll ' work ' as it ought to work,,, the recommended depth:width & max thickness can be found on the product sheet,,, this ain't apron store stuff you'll need to get supplies from a pro const supply house,,, IF anything, in a pinch use the 100% silicone if you absolutely NEED to give $$$ to the apron stores
how to remove musty odor, waterproofing a cement block handydady Building & Construction 6 09-19-2008 08:54 PM
$4 per block for retaining wall? tmpyankee Landscaping & Lawn Care 7 09-10-2008 12:22 PM
Gluing greenboard to cement wall... tips? AdamB5000 Remodeling 5 03-31-2008 11:11 AM
Taking down a conc block wall Oilerz Remodeling 1 01-05-2008 11:23 PM
