Partition Wall Supported By Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 05:56 PM   #1
Rewards Points: 508
Partition wall supported by subfloor
I need to replace the subfloor in my bathroom, but I noticed the partition wall between the bathroom and the kitchen does not rest directly over one of the joists that run parallel to this wall. The plank subfloor is apparently all that prevents the sill plate from deflecting. The sink drain runs through the joist bay beneath this wall. What's the best way to replace the subfloor in this area? Would 2x4 blocking provide sufficient support for the wall?
benjamincall is offline   Reply With Quote
Old 06-13-2009, 08:50 PM   #2
Rewards Points: 508
Scab?
What about some sort of plywood scab where the planks meet the new plywood subfloor? If that solution is viable, what type of fasteners would you recommend?
Old 06-13-2009, 09:47 PM   #3
Rewards Points: 5,336
I'd cut back the subfloor to the last joist before the wall. Sister on another joist and start the new subfloor on the sistered joist.
Ron
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Loads on a partition wall acyate Building & Construction 8 02-28-2009 11:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
