Partition Wall Parallel To Ceiling Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 05:43 PM   #1
partition wall parallel to ceiling joist
Hey, Everybody.
I am building a non-load bearing wall that is parallel to the ceiling joists. The ceiling joists are 2 x 6's. The 2 x 4 wall will go directly under one of the joists. I am not sure how to make it so I have a place to nail in the ceiling drywall where the ceiling meets the partition wall. In the attached picture, it shows a ceiling nailer. However, I am not sure exactly what's going on there.
What am I missing?
Thanks in advance!
Red
RedBear is offline   Reply With Quote
Old 03-04-2010, 06:08 PM   #2
Top plate looks like a 2x8
They probably lowered the whole ceiling that way
Or maybe they did not put in a ceiling ?
---altho the cut away version in the right looks like they did ?
Or they nailed a 2x4 to each side of the 2x6 joist ?
That seems like its easier
Old 03-04-2010, 08:04 PM   #3
lose that picture.... to confused.
Lots of ways to add the nailer... We need to know exactly where your wall
will be " under the floor joist" to advise simplest way.
double top plate will allow easy secure of drywall at top on the walls after ceiling is rocked.
Big Bob is offline   Reply With Quote
Old 03-04-2010, 09:40 PM   #4
Consider the picture lost. ( DIY book)
I am actually flexible where I can put the wall in relation to the ceiling joist. I was planning on centering the 2 x 4 wall on the edge of the 2 x 6 ceiling joist. However, if there is an easier way to do it, I can shift the wall an inch or so either way.
By the way, Bob, I am not sure what you mean when you say, "...after ceiling is rocked." Can you explain?
Thanks for your time.
Red
Old 03-04-2010, 09:50 PM   #5
As I see it the problem is having something to attach the ceiling sheet once the wall is built
If the wall is built right under the rafter (top example) then you have a problem
If you attach a 2x4 or 2x3 sideways then you have something to attach to
Bottom example
Will the wall be finished on both sides ?
Old 03-04-2010, 09:55 PM   #6
Registered User
Rewards Points: 526
Either add a 2x4 flat or on edge as in Dave's post, or blocking every 24" between the joists, if not TJI's. Or a simple solution is just 2x2" metal flashing nailed to the top plate of the wall, screw the ceiling to the other 1/2.
Be safe, Gary
Old 03-04-2010, 11:54 PM   #7
usually ill try to cut blocks the same size as the ceiling joists i.e 2x6 / 2x8 spaced 24" O.C.
partition wall parallel to ceiling joist-test.jpg   partition wall parallel to ceiling joist-test2.jpg
lemon714 is offline   Reply With Quote
The Following User Says Thank You to lemon714 For This Useful Post:
Scuba_Dave (03-05-2010)
Old 03-05-2010, 12:14 AM   #8
or nowhere near as strong or preferred 2x4 nailers.
leading cause of nail pops or cracked seams in drywall is inproper fastening / not enough material to fasten to.
partition wall parallel to ceiling joist-test3.jpg   partition wall parallel to ceiling joist-test4.jpg
Old 03-05-2010, 07:22 AM   #9
Much better pics !!
Old 03-05-2010, 04:21 PM   #10
I see. The preferred/sturdiest way is to have a 2 x 4 running the length of the wall.
Yes, both sides of the wall will be finished. So, if I center my 2 x 4 top plate on the 2 x 6 joist, I will have an inch on each side of the joist to nail in 2 x 4 nailers.
I like Bob's suggestion of the double top plate to make nailing the drywall for the wall easier.
Thanks for getting me going again!
Red
The Following User Says Thank You to RedBear For This Useful Post:
Big Bob (03-05-2010)
Old 03-05-2010, 11:37 PM   #11
jlhaslip's Avatar
Rewards Points: 2,862
Usually the blocking is laid on the flat between the joists on about 24" centres to give you a place to nail the wall plate and drywall backing using the blocking. Similar to the image posted above, but turn the 22 1/2" blocking on the flat.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Interior Wall Stud Joist Connection Issues. Brandnewruins Carpentry 5 04-22-2009 11:46 PM
A Garage Steel Stud partition wall PaliBob Building & Construction 8 02-16-2009 03:32 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 05:07 PM
