Partition Wall In Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 06:06 PM   #1
Partition wall in garage
I want to build a partition wall in my garage. It will run parallel to the garage doors. I'm just going to use the space as a work shop. I'm not planning on running any electrical in the wall and plan on tearing it down once I sell the house. I'm also planning on putting a door in the wall, so I can access the garage.
Do I need a permit for this job? I pulled some permits in the past when I replaced some sheathing and did some minor framing. It was rather expensive.
I still want to do the job to code.
pomelo is offline   Reply With Quote
Old 11-23-2009, 06:26 PM   #2
Civil Engineer
Rewards Points: 4,568
If you want to know if you need a permit, ask the local permit enforcement officer. If you want to do the job to code, get a copy of the code.
Daniel Holzman is online now   Reply With Quote
Old 11-23-2009, 07:09 PM   #3
Rewards Points: 5,336
Pretty sure you will need a permit. Door and wall will probably need to be fire code.
Ron
Old 11-23-2009, 08:47 PM   #4
Ron
I might not do it if I have to pull another permit. The last time I pulled a permit the inspector came to my house for less than 2 minutes. He didn't even turn off his truck. He just walked up and glanced at the framing and initialed off on it.
I would still need to make the door and wall up to the fire code even though the existing wall and door are up to code. Is this correct? Do you know of a temporary wall system I could put up (maybe buy)? I was planning on adding a window unit to the space and need to block it off.
Old 11-23-2009, 08:59 PM   #5
By installing another wall you are creating a new habitable space
So as far as I know you need a fire wall & door
Talk to your Inspector....he will tell you if it needs to be a fire wall
Temp wall doesn't matter, as many walls that are Temp stay up for decades
Old 11-23-2009, 09:56 PM   #6
Rewards Points: 1,016
In some areas this would constitude a conversion to living space - in that you can no longer park a vehicle in the garage. Sometimes not allowed, or allowed with proper alterations.
I converted my garage to a hobby room / workshop - finished off the walls and ceiling, epoxy painted floor, installed package HVAC unit, installed new electric and lights, etc. A wall blocking the garage doors was not allowed by the city.
Old 11-23-2009, 10:09 PM   #7
As far as I know a window between the garage & habitable space is not allowed
Is there a garage door on the side you are closing in & are you keeping it ?
Old 11-23-2009, 10:46 PM   #8
Yes, there is a side door and a window. I plan on keeping both. I was planning on blocking off quite a bit of the garage, so I would no longer be able to park a car.
I'm planning on getting a material list tomorrow. I haven't had a chance to look at the building code book or NFPA books. I'm guessing I would need to put 5/8" drywall on both sides and a steel (exterior door). Is there anything else related to fire protection?
Thank for the help by the way.
partition wall roxy Building & Construction 3 03-03-2009 12:01 PM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 04:39 PM
Frost Build Up On Interior Garage Wall richw Building & Construction 8 01-06-2008 10:47 AM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 11:23 PM
