Partition Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 10:35 AM   #1
partition wall
I WANT TO DIVIDE MY KIDS ROOM AS THERE IS A LARGE AGE GAP BETWEEN THEM SO THEY HAVE THERE OWN SPACE. THE ROOM IS QUITE LONG AND HAS FITTED WADROBES AT THE DOOR END. HOWEVER IT ONLY HAS ONE WINDOW IN THE MIDDLE. I WOULD LIKE TO PUT UP A PARTITION WALL BUT HOW DO I DO THIS AS THERE IS ONLY ONE WINDOW AND TO GIVE THEM BOTH ENOUGH ROOM I WOULD HAVE TO SPLIT IT DOWN THE MIDDLE. ANY IDEAS WOULD BE WELCOME
roxy is offline   Reply With Quote
Old 03-03-2009, 11:12 AM   #2
Remodeling Contractor
possible make two separate private areas and a common area that utilizes this window.
Old 03-03-2009, 11:39 AM   #3
Rewards Points: 3,130
If you want to make two bedrooms, you'll have to put in another window. It must be an egress window. And depending on the size of your existing window, you may have to replace that too.
Old 03-03-2009, 12:01 PM   #4
Registered User
Termite's Avatar
You definitely don't want to make egress from the bedroom difficult...Either via the door or via the window. If the room is divided then another egress window would in fact be required, and another door to the exit path might be a good idea.
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
A Garage Steel Stud partition wall PaliBob Building & Construction 8 02-16-2009 04:32 PM
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 08:54 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
