Parging On Outside Of Concrete Block Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 05:31 PM   #1
bubbler's Avatar
Rewards Points: 256
parging on outside of concrete block basement
I have a home with a concrete block foundation. The parging on the outside of the foundation is in tough shape, it's either missing or brittle the point of falling apart at a slightest touch.
I can see that the mortar as eroded out from between the blocks in a few places, particularly below grade. This is scaring me because on top of a water issue that I'm sure is created (or at least made worse) by these issues, I have visions of a termite/bug superhighway from these cracks inside the block wall to my sill... I might not even know I have a problem until the termites have eaten their way from the inside out on the sills...
What should I do about this eroding mortar? should I dig down and try to patch things up w/ some cement or other material?
Is the parging aesthetic or does it have some function? Meaning, should I be thinking about replacing/repairing it, or just let it fall away knowing the only downside will be appearance?
bubbler is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 10:21 AM
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 05:40 PM
