Old 11-04-2009, 09:00 PM   #1
Default Parging Interior Basement walls?
I live in S. Ontario is a house built in the 30's. I am about to start a basement reno and I've found that the interior (and exterior) walls in the basement are in rough shape. The parging is crumbling and falling off. I've attached a photo so you can see what I'm dealing with. I am completly new to this and don't know where to start.
It has been suggested that I should clean and re-parge the walls. Does this really need to be done if I'm framing and dry walling? Can I get get away with just covering it over?
Thanks in Advance.
Gibson is offline   Reply With Quote
Old 11-04-2009, 09:50 PM   #2
In your case, its unlikely that the walls can be repaired from inside.
The outside of the walls will need to be excavated, the wall surfaces parged and waterproofed or at least waterproofed.
Drainage tile would be installed adjacent to the footings and run to a sump pump.
Parging the inside will do no good and is a waste of time and money.
I'm planning a similar job and I plan to have foam insulation sprayed on the inside wall, then I'll erect a wood frame wall over top.
I'll also insulate the stud cavities, as well. (with R12 Roxul)
Old 11-05-2009, 08:07 AM   #3
he's right,,, w/o resolving the wtr/wtr vapor issue outside 1st anything you do inside'll be wasted effort/mtls,,, you can get away ' w/covering it as long's you realize the damage'll still be taking place inside AND outside,,, after all, it IS your home,,, i wouldn't in mine, tho.
forget listening to whoever gave you that suggestion, too !
itsreallyconc is offline   Reply With Quote
More On This Topic
Paintball sport fans often build elaborate defensive positions for both indoor and outdoor facilities. One good defensive position to build for outdoor paintball fields is a standard U.S. Army-style foxhole. Read More »
Straw homes have come a long way from the days of the "Three Little Pigs." Despite the fears of traditional homebuilders, homes made from bales of straw have proven to be structurally sound, well insulated and environmentally friendly. Another big... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about insulation tips. Now that our wall is fully framed in, we can go ahead and insulate. When buying insulation, there is a couple of things that you want to look for... Read More »
Garage Wall Insulation Tips
Garage Wall Insulation Tips by Expert Village
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 08:09 PM
parging concrete walls newzev Tools 7 07-27-2009 03:54 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 10:17 AM
Staining Interior Basement Concrete Walls techinstructor Painting 0 03-15-2009 04:15 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing 4 02-18-2008 04:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
