Parging A Basement Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2009, 09:25 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Parging a basement floor
My basement floor is very rough, especially the crawlspace portion of it. I've been toying with the idea of parging a smooth surface to it using parging paint mixed with adhesive, before I paint. Think this would be a good idea? Or would it crack and start to chip over time?
The floor is very dusty and hard to clean. I can vacuum/scrub all I want but there is always dirt.
Old 11-17-2009, 09:31 PM   #2
Rewards Points: 1,010
And that will be a problem, any covering you apply will adhere to the dirt, and not the underlying floor
Anti-wingnut is offline   Reply With Quote
Old 11-18-2009, 06:27 AM   #3
Remodeling Contractor
you can use a mix that will work without cracking for thin coats. It will be expensive. For basic cement you need to use at least 2" thick. For any work the old concrete must be cleaned and in good condition. Cracks filled, spalling (the loose or chalky concrete) ground down with a cone wheel. I think you are better off covering with 6 mil plastic, plywood and flooring.
Basement Floor Leak Celtic DIY Plumbing 5 08-04-2009 10:32 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 08:06 AM
Can floor jacks in basement be permanent? ragtopdave06 Remodeling 15 03-15-2007 05:23 PM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 01:58 PM
