Parge Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 07:29 PM   #1
Parge Cement
I am in the process of flipping a house. The house aggresively textured stucco on the rear and side foundations. The front foundation is stone veneer.
I wants to cover his entire foundation with white parge concrete. I want to have the parge to be white in color. What would be to proper way to do this? Would I have to remove the veneer and stucco and expose the block to parge or could I get away with putting lath over it all? Also how would I color it white? Thanks.
deathwish is offline   Reply With Quote
Old 06-08-2010, 05:45 AM   #2
Rewards Points: 4,750
if you can get the wire mesh to stick, that's be my choice,,, plaster & white cement = white parging/stucco,,, why white is your decision, tho !
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 08:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
