Paralam Support Question.... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-18-2007, 09:42 AM   #1
Rewards Points: 150
Paralam support question....
We put a 2 story addition on our house that is 18x18. The floor joist's for the upstair's are 2x10's hung off a 14" paralam (to get max ceiling hight in the downstair's) that is 18' long.
What should be under each end to support the 14" x 18' paralam and 2nd floor?
PS - The 2nd floor is just a bedroom.
dcd22 is offline   Reply With Quote
Old 07-18-2007, 10:35 AM   #2
Rewards Points: 5,336
Whatever the Architect specified. Could be concrete filled 4" metal support poles, a series of 2x4's, etc...
Since it seems it's done, what's under it now?
Ron
Old 07-18-2007, 11:04 AM   #3
Rewards Points: 150
It is 2 2x4's sistered together. I did not have architect plans drawn, my builder and myself drew them, and they were approved and inspected by the town. I assumed all was OK, but when I sit under it I sometimes wonder!
Old 07-18-2007, 03:53 PM   #4
I took the first floor out when I put the kitchen addition on. I used 2- 1 3/4" x9 1/2"x 14' lvl's sandwiched around a 1/2"x 9" x14' flitch plate and bolted together along with the 14' lintel to hold up the second storey brick. I used the concrete filled metal poles.
I designed the addition and had a draftsman make up the blueprints. He worked with an architect who over saw the structural considerations and signed off on it. Cost me $700. vs. the $4500. an architect wanted to do the same thing.
Ron
Old 07-19-2007, 07:41 AM   #5
Extreme DIY'r Adk's, NY
Rewards Points: 272
shoot from the hip engineering, I was guessing 3 2x4's nailed together under each end before I read your later post. They are extremely strong in compression but two are more likely to bow and thus settle than three. Also, and just as importantly, is the bearing area calculation based on the load. 3 2x6's in compression was signed off on a plan I did myself supporting a 2nd floor lined up with load bearing walls of roof loads supporting three 2x12x32 foot lvl's with a span of about 16' (3 posts).
crecore is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 12:15 PM
Hello People, New Here and have a question Hillman Building & Construction 4 02-21-2007 06:16 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
