Paper/Tyvek Hanging Out Under Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 02:08 PM   #1
Paper/Tyvek hanging out under siding
We just bought our first house last year, and in the back of the house, there are sheets of plasticized paper/Tyvek hanging about 4" from under the last sheet of vinyl siding, right above the foundation. When i lift it up and look beneath it, I can see the edge of the wooden floor or baseboard that sits on the concrete foundation. There is nothing covering the wood except for the flimsy paper and siding.
Do I need to cover this wooden edge with flashing to protect it from the elements? I want to cut off the 4" of paper hanging out because it's ugly and curling up, but I'm afraid that's the only thing protecting the exposed wood from moisture.
violetUK is offline   Reply With Quote
Old 05-24-2010, 05:42 PM   #2
The vinyl siding should be attached to the sheathing & protecting it
Siding should not be loose
Sounds like they didn't use a starter strip
Any pic ?
Old 05-24-2010, 06:36 PM   #3
kwikfishron's Avatar
Rewards Points: 600
Don’t cut the paper.
The Vinyl installers did not install the partial course of siding to cover the wood plate.
You should hire someone who knows how to install Vinyl Siding.
It’s a pretty easy fix if you know what your doing and have the couple special tools it takes to make the job easy.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (05-25-2010)
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-22-2009 11:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
