Panel Glue Off Sheet Rock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 06:37 PM   #1
panel glue off sheet rock
i am working on the walls of my house i just boaught. i took the paneling of my walls and the glue is still on. i tried using my little hand held sander but it just isn't doing the job. since i don't have the funds to tear down and put back up what is the best sander to use on sheet rock with out ruining it?
richard1980 is offline   Reply With Quote
Old 09-17-2010, 08:45 PM   #2
Rewards Points: 502
sanding wont be an option. the glue is harder than the sheetrock.
forresth is offline   Reply With Quote
Old 09-17-2010, 09:02 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Most of that kind of glue is tough and is tough to get off the rock. You may have to take a putty and scrape it off and very possibly it will pull the paper off the rock where the glue is. You can come back and mud that back in and sand when dry and hopefully save you a few bucks. Let us know what you decide to do and how it comes out.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
seeing studs thru sheet rock fieta Building & Construction 8 03-09-2010 06:47 AM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
