Panel Codes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 11:36 PM   #1
panel codes
A friend recently asked me to build him some cabinets and a wet bar in his basement that was recently renovated. I went to visit and found what I think are a few problems. 1). Where the sink is to go in the bar there is the breaker panel about 2 feet above.Can you enclose the panel to meet code???? 2) In the past with building bars in the basement I've anchored the base for studiness, but in this case he has put a heated tile floor,which eliminates that approach. How can the bar be fastened?? ( I'm thinking PL 400 or adhesive of some sort) Thanks for your input.
Ontario
deman480 is offline   Reply With Quote
Old 05-19-2009, 06:08 AM   #2
NEC, USA, requires a working space 30" wide, 3' deep around a service panel, so no, you can't put that sink there, or the bar for that matter.. Check Canadian code, but I suspect it is similar.
I would not rely on adhesives, bolts with anchors, tapcons, etc, woulds be some of my choices. You can anchor a 2x4 to the floor, set the bar frame over the 2x4 the anchor the framework to the 2x4.
Old 05-19-2009, 06:12 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, I am not sure of what the Canadian Building Codes may say, but the concept behind this particular code, is to allow an averaged size "fireman" to be able to fit into the space, in order to perform an emergency shut-off of the home's electrical system, were that need to occur. Thus, the panel cannot be re-stricted, or blocked and requires a minimum area (per code stipulation), around it.
- Build Well -
Old 05-19-2009, 04:33 PM   #4
panel
Thanks guys, will consider all.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
