Old 10-15-2005, 11:07 PM   #1
paint over brick ?
How adviseable would it be to paint over brick on an older home? are there special primers, prep, or kinds of paint that must be used? What about the liquid siding products? What is the life expectancy of paint on bricks? What do you do down at the foundation line- paint down below the soil and build up the flower beds? Thanks for any advice!
marlenecapps@cox.net is offline   Reply With Quote
Old 10-18-2005, 10:36 AM   #2
paint over brick ?
Marlene,
A good power wash is usualy the only thing that is needed to clean the grime and loosen up small debris from the brick and mortar. Any good paint or hardware store will have brick paint and it will last almost forever. If you change your mind down the road though, it is almost impossible to completely remove. The foundation can be painted with a good concrete paint but beware of building up flower beds at the wall as sometimes this can lead to water seepage in the basement. Your grade should always be sloped away from the wall for water run off.
'Andyman is offline   Reply With Quote
Old 10-29-2005, 08:30 AM   #3
paint over brick ?
Wa************, or have it done.
Prime it. It will take a lot, because the brick will soak up primer like a sponge, and paint it. Paint sticks to brick so well, you will never believe.
kesac is offline   Reply With Quote
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
stripping paint off of brick! help revcex General Discussion 8 11-24-2006 02:39 PM
How to remove paint from brick beezee3 Remodeling 2 12-28-2005 02:38 AM
