Packing Out Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 02:23 PM   #1
Ejm
Packing out walls
Hi,
I am remolding my bathroom and the walls are 2x3, including the wall where the door is located. It is a non-load bearing wall. I want to put in a standard 4 1/2" door frame, but I know that will sit proud of the sheet rock. Does anyone have any ideas on how I can fur out the walls to make this work? Thanks!
Ejm is offline   Reply With Quote
Old 04-12-2012, 03:32 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
Buy a standard door with an 4 9/16 jamb and trim an inch off the non-opening side. You may be able to do the same with a split jamb door.
Coastal South Carolina
Old 04-12-2012, 06:57 PM   #3
Ejm
Thanks!
Old 04-12-2012, 07:13 PM   #4
Rewards Points: 2,212
If your staining the Jamb make sure it is solid wood, some are MDF or plywood with a veneer on it.
mae-ling is offline   Reply With Quote
Old 04-12-2012, 07:17 PM   #5
Ejm
It will be a hollow core that will be painted. Thanks
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 04:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
