Packed Dirt Under Old Tub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 11:49 AM   #1
Post
I demolished a cast iron recessed tub on the second floor of a house built in 1948. Not sure if the salmon colored tub was original (seems like a very '70's color). I found dirt packed between the joists. (See pic)
Why would someone pack dirt under the tub ? I can't imagine it was for support as the dirt was firm only in some sections.
May I remove the dirt without negative impact ?
I'm replacing tub with a new cast iron model.
nixplix is offline   Reply With Quote
Old 01-10-2010, 12:51 PM   #2
I'm just guessing...
Maybe structural to "spread the load" of the tub?
Maybe insulation to keep the water warm in the tub longer?
Or maybe there was an old tub, it was removed and there was mold there? And maybe they used the dirt to absorb moisture and as mold remediation?
Billy_Bob is offline   Reply With Quote
Old 01-10-2010, 01:24 PM   #3
Those are excellent points. I wonder if the dirt might have also served as a noise dampener. I suppose folks in the kitchen below might hear the shower running above. Maybe some insulation could prevent that - going forward. I'm going to remove the rest of the dirt and inspect the condition of the boards. Thank Billy Bob
Old 01-10-2010, 06:17 PM   #4
Licensed Engineer
Rewards Points: 175
Vermiculite insulation?
Vermiculite is a naturally ocurring mineral and can look quite a bit like dirty sand. Unfortunately, it is either a cousin of asbestos or commonly found with asbestos and can be quite a hazard in its own right.
MI-Roger is offline   Reply With Quote
Old 01-13-2010, 11:28 AM   #5
RE: Vermiculite Insulation
I don't believe this is vermiculite. Whoever dumped this stuff included shards of glass and electrical cable. Thank goodness I wore a mask during demolition, although I don't know it would help much had it been vermiculite.
Old 03-16-2011, 07:48 PM   #6
rvSDVSDV
Jonnyss is offline   Reply With Quote
Old 10-20-2011, 12:16 PM   #7
@ NixPlix
What did you do with this issue? i have the same problem but only difference is the tub is on the 1st floor...I peeked at the other end of the tub and saw dirt and planning to take the tub out in 2 weeks time...What do you guys suggest for me to do and outside the tub are concrete...Bathroom size are 9X7 posting pics later on after uploaded in laptop....thanks...
HanDYI is offline   Reply With Quote
Tags
bathroom tub
Bathroom demo day - dirt under the tub?? vsheetz Plumbing 16 07-25-2015 02:20 PM
cinder block and dirt foundations gatojojo Remodeling 1 06-20-2009 06:35 AM
Rats! Tunneling into my dirt crawlspace! PastorErik Pest Control 7 05-06-2009 09:27 AM
Protecting siding base in dirt Bambu Building & Construction 11 08-11-2008 09:19 PM
Is there a proper fill dirt for grading? Sonabi Landscaping & Lawn Care 2 04-18-2008 11:23 PM
