Oversized "stadium Seating" Deck Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2012, 07:04 PM   #1
Oversized "stadium seating" deck stairs
I recently removed an above ground pool and replaced it with a paver patio. Now, I'm left with a deck that was cut around 1/3 of the pool, that opens up to nothing, just the patio below.
I would like to build oversized "stadium seating" stairs that go down to the patio. The height of the deck is such that a 6 step stringer would fit perfectly, however I want something like 3 oversized steps for sitting around the patio.
Does anyone have suggestions how to do this? Ideally I would use oversized stringers, but that would require boards larger than 2x12.
Thanks!
DREWG84 is offline   Reply With Quote
Old 12-02-2012, 07:19 PM   #2
Rewards Points: 13,458
Easyest way would be to built a platform 1/2 way down. The platform would act as your step.
Old 12-02-2012, 08:03 PM   #3
joed's Avatar
Rewards Points: 12,446
Best way I can describe is to build three steps extra wide. At the back of each step install a bench.
Tags
deck , patio , stairs , steps , stringers deck stairs
How to build deck stairs like this djinlondon Building & Construction 9 05-28-2012 03:13 PM
Box steps or stringer for a deck stairs drtbk4ever Building & Construction 2 05-15-2012 09:54 AM
Adding stairs or ramp to existing deck cluelessone Building & Construction 3 07-10-2011 04:39 PM
Adding Stairs To A Deck WBNC Building & Construction 19 08-06-2009 09:54 AM
Hanging deck stairs on a cantilever drtbk4ever Building & Construction 11 07-14-2009 08:13 AM
