Overlapping Wood Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 02:24 PM   #1
Rewards Points: 22
Overlapping wood siding
My garage and small tool shed have overlapping wood siding. The corners have L shaped galvanized steel nailed on which gives it a finish and protects it when banged by something. The top end tucks under the board above and the bottom curves under the board it is nailed to. Don't know what you call them. I need to replace some but cannot find them in Home Depot or hardware stores and even tried a couple of roofing companies. My description is admittedly poor but if anyone knows what I am talking about what are they called and where can I buy replacements?
Ronnie1a is offline   Reply With Quote
Old 02-05-2011, 02:32 PM   #2
Framing Contractor
Maybe something here can help. What is the exposure on the siding?
http://www.prosidingaccessories.com/...iding.html#259
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
Ronnie1a (02-05-2011)
Old 02-05-2011, 03:14 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
they can also be bent up in the field if you just need a few
Overlapping wood siding-0108001100.jpg   Overlapping wood siding-0108001101.jpg   Overlapping wood siding-0108001102.jpg
Tom Struble is offline   Reply With Quote
Old 02-05-2011, 06:00 PM   #4
Rewards Points: 22
Joe-thank you
Your internet site was right on the money.
Siding installation (vinyl, wood & aluminum) asmith_01 Carpentry 2 01-06-2011 06:38 PM
Existing wood siding and roof intersection. Valeriewg Building & Construction 1 10-28-2010 05:00 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
