Overhead Storage In Steel Frame Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 09:25 PM   #1
Overhead Storage in Steel Frame Garage
Do I have to do anything special to hang overhead storage in a steel frame garage? Monster Rax, for instance, says their shelving can't be used in a steel frame house, but ... why not, if I use self-tapping screws to mount it? Any information is appreciated!
woof01 is offline   Reply With Quote
Old 01-03-2011, 09:32 PM   #2
Rewards Points: 558
Thats because youd rip the metal screws right out of the metal frame and kill yourself or do some damage to anything under the shelving unit which was not properly fastened to structure.
epson is offline   Reply With Quote
Old 01-04-2011, 10:28 AM   #3
Looking for solution
Yes, thanks, I understand that. So is there a way to safely hang overhead storage in a steel frame garage?
Old 01-04-2011, 10:53 AM   #4
concretemasonry's Avatar
Rewards Points: 2,608
The warning about hanging the storage from a "steel frame house" probably is intended for typical "wrinkled tin" steel stud structure and is there to protect the storage unit supplier from liability problems.
1. Is your "steel frame" garage designed to accept the added storage unit loads and possible overloading? This would include eccentric loading to the frame and unbalanced loads.
2. Are the garage members you are attaching the storage unit to adequate for the new concentrated loads and are the members thick enough to develope the necessary strength with a self tapping screw? We all know you can put a self tapping screw into places it should not be.
Just a couple of heads-up questions. I am sure the storage units are adequately designed.
Dick
concretemasonry is online now   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
woof01 (01-04-2011)
Old 01-04-2011, 01:57 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,410
Ayuh,... I'd think that building free standing storage, then just attaching to the building for stability would probably work...
Bondo is online now   Reply With Quote
Old 01-04-2011, 02:16 PM   #6
Rewards Points: 558
Here you go pick a rack: http://www.rebsteel.com/racking-syst...lications.html
Tags
garage , shelves , steel frame house , storage
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 8 10-19-2011 11:58 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Garage subpanel installation - EMT ScottR Electrical 26 06-11-2009 12:53 PM
A Garage Steel Stud partition wall PaliBob Building & Construction 8 02-16-2009 03:32 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
