Overframing Hip Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 11:08 AM   #1
Rewards Points: 1,910
Overframing hip roof?
I've got your basic rectangle shaped house (40'x 27') with a hip roof. Roof framing is all 2x6. I'm adding on a large addition to the 27' wide end that will make the house essentially L shaped. The new addition roof is higher than the existing roof so I need continue the existing house ridgeline so that it "dives" into the new roof.
A few folks have told me to leave the existing hip roof structure and just overframe the existing roof. The existing roof framing is all sound. The other alternative is to completely remove the hip and jack rafters on that end (basically the last 14 feet of the roof) and just replace with common rafters that match the existing common rafters.
If you were doing this which way would you go.
Old 06-15-2009, 10:47 AM   #2
Any contractors out there with advice on this?
Old 06-15-2009, 07:01 PM   #3
Registered User
Rewards Points: 5,514
The old roof hip is a 2x6, but today has to be one size larger than the commons. 24"o.c., IRC says 2x6 will span- 11'9" only, with no snow load. So it should be 2x8= 14'10" span. Plus it has to hold the new over-frame and ridge of new. I would build it to the second choice for certain.Leave the old ceiling joists. Be safe, G
Old 06-16-2009, 05:15 PM   #4
Thanks Gbar, I think you got me on the hip size. I don't recall noticing the 2x6 jacks sticking down below the hip so I'm betting that I didn't pay enough attention to realize that the hip was a 2x8. I'll have to take a look again.
The rafters are all 16" oc so I just pulled up Table R802.5.1 (3) which should be correct for my situation (30 psf snow, 10 psf dead). Looks like the 2x6s aren't enough unless they happen to be select which I doubt (but will certainly check for). The overframe itself shouldn't put the roof above the 10 psf dead load because I'm planning on removing the old shingles before overframing.
Old 06-16-2009, 06:44 PM   #5
Old School
Willie T's Avatar
I'm in the process of working up some concepts of that very thing for a friend.
This matches a 10' high addition to a standard 8' height existing house.
If you have SketchUp, I'll send you the file so you can play with it.
Overframing hip roof?-mcglinchey-house-test1.jpg   Overframing hip roof?-mcglinchey-house-test2.jpg   Overframing hip roof?-mcglinchey-house-test3.jpg   Overframing hip roof?-mcglinchey-house-test4.jpg
Willie T
Old 06-18-2009, 08:58 AM   #6
Thanks Willie but I don't have Sketchup. Looks like a neat program.
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
