Over Garage Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 01:30 PM   #1
Rewards Points: 150
I am thinking of doing an addition over my garage. It is your typical 2story house with a single garage. The roof over the garage is just attic space now, total measurement's are 11 x 33.
Will there be an issue with the foundation in the garage and going up a full two stories? I am not sure if that was made to carry the excess load or not. I want to make this a master bedroom and bath, and was hoping to speand in the $20K to $25K range. If there is a foundation issue, that will not work!
House was built in 1987 also.
dcd22 is offline   Reply With Quote
Old 10-28-2008, 02:17 PM   #2
I wouldn't expect a big difference in the load-bearing capability of the garage foundation and the house. Usually local code governs the footing and foundation of structures, and usually specifies a minimum foot depth, which will influence your foundation height, thickness, etc. I'd say off hand the biggest structural issue you'll have will be properly supporting the floor, especially where it spans over the garage door.
o_jay66 is offline   Reply With Quote
Old 10-28-2008, 03:47 PM   #3
My guess is that there is already a footing around your garage especially since you share a bearing wall with it.
But I would look at the joist across the garage. That might be the big issue for you.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-28-2008, 04:17 PM   #4
Rewards Points: 150
What do you guy's think about the cost. I am in central NJ.
I am going to have the "shell" done by a contractor (framing, roof, siding and window's), then sub out the, HVAC, plumbing and Drywall. I will do all the electric, flooring, trim and finish work in the bathroom. Also, the new bath does back up to a current bath so all plumbing is close by.
Old 10-28-2008, 04:41 PM   #5
Less than $100,000.
I have no idea. Costs are a lot higher in your neck of the woods.
Old 10-28-2008, 05:59 PM   #6
Rewards Points: 5,336
Price point seems low. I would put it in the 35-40K range. Finish products will drive the cost up based on taste.
Ron
Old 10-28-2008, 06:01 PM   #7
Ron
Ron, reread my post and the estimate.....
This is my dry sense of humor.
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 02:46 PM
garage addition richard35 Electrical 13 01-22-2008 05:33 AM
Question on garage addition; not on building but design/layout 52Caddy General DIY Discussions 3 11-22-2007 09:09 AM
