Over 8 Foot Wall - Method of Applying Sheathing...
17K views 14 replies 7 participants last post by  Daryl
The project I'm currently working on has 10 foot sidewalls. Useing 8 foot tall OSB, what is the recomended way to handle this?
I'm assuming it is acceptable to apply the 8 foot sheets to the walls then fill the remaining with two foot pieces. Is this an acceptable method or is there a better way?
This only comes into affect on the side walls, not the gable end walls.
Thanks, Adam
Apply the sheathing horizontally as per usual, with 1" gaps. 2 1/2 rows and it's done. Sheathing is designed to be laid horizontally not vertically. It probably doesn't matter if you're in some corner and you put a piece in vertically, but if you're considering the whole job do it the way the engineers speced it and everyone will be happy. Anyway, it's easier and faster. :thumbsup:
#5 ·
All of the jobs are typically done vertially here since OSB is the sheeting of choice and it's uni directional so it makes no difference it you run it horizontally or vertically.
When buidling tip up walls laying it horizontally works pretty well, if walls are constructed and easy to reach at ground level it's typically installed vertically.
If you want to really make life easier, install your filler at the bottom then set your full sheets on top of that.
#6 ·
" 1" gaps, where?"
It's code here to leave 1" horizontal gaps in the sheathing to allow for moisture escape. This is generally done between the first and second sheets, so you wind up with a 1" gap running around the building at 4'. I take it this isn't common elsewhere?
#8 ·
Bonus said:
" 1" gaps, where?"
Your right! I've never heard that before. We just put a nail beetween the sheats and run them horizontally and it doesn't matter how tall the wall is whether it's 8', 9' or 10', we start at the bottom where the sills are and go from there.
#9 ·
Joe, that sounds good to me and always did til I got called on it once and had to go around the building 'retro-creating' the 1" gap.:furious: Now I put it in every time. It really doesn't make much diff, just a nail at 1" or not, doesn't slow anything down. Rich.
#13 ·
I'm not in Canada you know, I'm in Canada, eh? :)
" US energy codes require all gaps in structural sheathing in the thermal envelope to be sealed.
Otherwise you increase the likelihood of moisture condensing in the wall cavity and create a less energy efficient wall assmebly in the process."
Yeah, it's curious that we have two opposite ideas with the same outcome in mind. The inspectors here insist that this is to allow moisture that makes it through the VB to escape.
