Oven Venting - Necessary? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2009, 10:27 PM   #1
Rewards Points: 41
Oven venting - necessary?
Still feeling out the nuances of a recently purchased house...
Turned on the fan/vent above the oven today, and wondered about the venting. Looked in the cabinet above it and found that the venting had been removed and the hole sealed up. Went to the attic, and found that the cut into the attic had been filled in and thick "great stuff" filled the gaps.
Do electric ranges not need ventilation thru the attic to the roof? Is this OK?
kelley4180 is offline   Reply With Quote
Old 10-11-2009, 06:41 AM   #2
Electric ranges/ovens do not need vents for removal of combustion gases since there are none. But it is a good idea to vent to remove cooking odors and smoke. The best way is to vent outside, but recirculating fans with charcoal filters work fairly well.
Old 10-11-2009, 10:14 AM   #3
Rewards Points: 582
Don't know about your codes, but with ours you have to have mechanical ventilation in the kitchen, otherwise you can get a condensation problem. I've put ours over an electric range in an inglenook. The problem with our code is that it hasn't told my wife she has to switch it on.
stuart45 is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 09:48 AM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 04:20 PM
Restaurant code? for HVAC - oven venting, etc. pcampbell HVAC 3 06-26-2009 01:05 PM
