Outswing Patio Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2007, 02:01 AM   #1
Rewards Points: 160
outswing patio doors
Any tips? I've installed an 8' Marvin slider and many prehung inswing exterior doors but never done an outswinger (other than screen doors). Have a brochure from Codel (Tacoma, WA). Anybody tried them? We're in Oregon, the rainy part, and the doors will be S facing onto a low deck on a gable end of the house (no rain protection). Trying for < $600 for double doors, both active swing. Plastic seems like a better option than wood given house value (moderate), door location, and climate, but counter-arguments would be appreciated. Existing double door is inswing and just takes up too much space in the small dining room.
Be happy to supply more details (like RO and wall thicknes).
Thanks in advance,
Phil S
philS is offline   Reply With Quote
Old 07-10-2007, 10:26 PM   #2
remodeling pro
I have installed a couple sets of out swinging patio doors, and had no problems with them. In llocation without much weather protection, I feel they are actally less prone to water leakage, because the thicker part of the jamby is behind the door and creates a physical barrier for rain , in addition to the weatherstripping. Same for the threshold, since they mostly have a "jamb up" style of threshold, instead of just counting on a couple of vinyl flaps like most door bottoms have. I would definately use a quality fiberglass door blank. The vinyl jambs available on some units are a good idea longevity wise, but they require a lot of closely spaced shims to hold them straight, since the material is so flexible. Worth spending a few dollars for some true solid brass or stainless hinges, because the typical "brass" junk supplied with the door units will be rusty in a few months.
troubleseeker is offline   Reply With Quote
Old 07-11-2007, 02:39 AM   #3
Rewards Points: 160
That sounds like good advice on the hinges and hardware. Most of the brands I've looked at offer choices. These particular homeowner friends are usually pretty willing to spend the extra few bucks to save money down the road.
Thanks for the input. -- Phil
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Crestline Patio Doors tom_patriot Building & Construction 2 11-24-2006 11:51 PM
