Outswing Entrance Door In Garage. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2013, 06:00 PM   #1
Outswing entrance door in garage.
Are they available I haven’t seen any and it would be ideal for my needs. What about hinges I assume they are different. Any one have a good photo of one?
I did find some I think my opening is an odd size though. Florida I see requires out swing in some city’s. I did learn a few things thanks.
rodm1 is offline   Reply With Quote
Old 09-29-2013, 06:14 PM   #2
Rewards Points: 6,652
They are, but really you do not want from the living area into the garage, the door swinging out into the garage. Same goes for the door exiting into the outside world. Now of course you see a lot of basement entrances from the first floor, where the door swings into the basement, which it should not be.
Old 09-29-2013, 06:51 PM   #3
DIY staff
Rewards Points: 7,174
Most stores stock simple exterior doors in outswing---they are commonly used in garages----seldom used for a house because a screen door can not be used with it.
Old 09-29-2013, 08:52 PM   #4
In a little over my head
Rewards Points: 706
I have an outswing door from my kitchen to my deck. Inswing wouldn't fit. My local lumberyard has a millwork shop. They made it. You can either spec security hinges, or screw 2 lags into the edge of the door, cut off the head with a hacksaw, and drill matching holes in the jamb.
ratherbefishing is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Subfeed to New House from Existing Garage??? scuba.man Electrical 2 06-21-2012 07:54 AM
Wiring Garage Sconces paredown Electrical 1 03-28-2012 03:08 PM
Garage floor Tomperro Flooring 6 07-18-2011 12:30 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
