Outside Water Heater Enlocure - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 07:59 AM   #16
Rewards Points: 13,458
The only pressure treated wood you need is for the bottom plate.
Do not use pressure treated plywood for the walls or for the framing.
If you do then your going to have to use all ACQ approved fastners or there going to rust off in a year.
It would be best to have a row of block sitting on that slab, a top plate, then build the building.
If not the sheathings going to rot out from being to close to grade.
At least 4 or 5 times a year I get to tear down DIY pump houses. Most are eatten up with termites, rotten at the bottom, DIY doors falling off or rotted out, or the roofs caving in from not enough slope to the roof.
It's cheaper in the long run to build it right the first time and not have to do it all over again later.
What your trying to build is nothing more then a 3 sided small shed with a shed style roof. Same framing, just a smaller size. There's tons of on line pictures and plans on line and in books in any box store.
Old 05-09-2013, 08:55 AM   #17
MJ Force's Avatar
Rewards Points: 150
Originally Posted by Fishbone90
Aye. It's a beauty. Does it central vacuum too?
No but, if I route the cool exhaust directly over the wifey while she sleeps it help during any menopausal over-heating episodes
It's a hybrid HW tank. It exhaust cool air. Essentially it's a heat pump. Very efficient. If I lived in a very warm climate I would certainly install one of these.
MJ Force is offline   Reply With Quote
Old 05-09-2013, 08:31 PM   #18
Rewards Points: 57
The original enclosure is at least 5 years old and the wood is still in very good shape. I spent some time on it this morning doubling up (width) original 2 x 2" and added 2 x 4" to spots on the front and back to sturdy it. I am removing the old wood from the sides and plan to replace it with 1/2" ply PT. Are the codes nationwide for use of ACQ approved fasteners? Point being is PT is much better for Florida weather and termite resistance. Will build double doors using 3/8" ply with 1" x 4" perimeter.
Fishbone90 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
