Outside Vinyl Siding And Wall Bumps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 03:52 PM   #1
outside vinyl siding and wall bumps
I recently moved in a newly renovated home. As I sat in my backyard for the first time I notice a diagonal pattern of bumps in the siding. I immediately was alarmed so we went to check the inside and the microwave and oven were both up against this wall not to mention their were similar bumps on the wall. What could be the problem and can it be fixed? We had the home inspected. Would the inspection company take some of the responsibility?
facedema is offline   Reply With Quote
Old 05-14-2012, 04:02 PM   #2
Stay-at-home GC
Several things to check.
The thickness of the siding. Some of the cheap stuff is paper thin and telegraphs every imperfection in the sheathing.
Proper fastening technique. If the nails were driven tight to the sheathing the vinyl may be buckling as it expands and contracts with temperature changes.
Jimmy Hoffa?
As far as the Inspection Company being liable you would have to start with identifying the problem first. If it is Jimmy and you have to pay to have him removed then you might have a case. If it just cosmetic due to poor material selection, you probably don't have much of an argument.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-14-2012, 04:38 PM   #3
kwikfishron's Avatar
Rewards Points: 806
Welcome to the forum facedema.
How about posting a picture or two so we can see what you see.
How to attach a photo to a post
kwikfishron is online now   Reply With Quote
Old 05-14-2012, 06:30 PM   #4
KemoSabe
loneframer's Avatar
the bumps are probably the lap joints in the vinyl siding. Look at it from another angle and you might see the seams in the siding.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 05-14-2012, 11:07 PM   #5
The lone framer might be right if the bumps are uniform and following a pattern but it is most likely improper installation. When installing vinyl siding the nails must be placed dead center and 1/8" off the vinyl to allow movement. Also check to make sure they did not caulk the seams. That will also restrict the movement. It could also be cause by heat warping. That can be caused by a neighbors window reflecting the suns rays and heating up the vinyl which will also cause bumps. The manufacturer will have a disclaimer against that. If you have the money i would recommend changing to hardie siding (cement board). It will increase the R-value of your home by R-2.
askfrew is offline   Reply With Quote
Old 05-15-2012, 01:12 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
are you sure?
Tom Struble is offline   Reply With Quote
Old 05-16-2012, 06:18 PM   #7
For someone that owns a siding and trim company you should know it's not a lie. You must sub everything out.
Old 05-16-2012, 07:03 PM   #8
you show me where Hardie has an r2 and i will retact that
Old 05-16-2012, 07:12 PM   #9
You should be up to date on the products you install. You should read qualified remodeler or remodeling magazine. It will help with being date on the different products out their. Answer this, what does the R mean? You might just want to keep installing. For having 26 years of experience of not knowing what yiu install.
Askfrew out
Old 05-16-2012, 07:20 PM   #10
http://www.jameshardie.com/builder/pdf/ner-405.pdf
maybe i can help,check page 31
siding industry is rife with people making claims about r values and energy savings that are not true
Old 05-16-2012, 07:26 PM   #11
Framing Contractor
Rewards Points: 120
Never heard anybody try to sell hardi by promoting the R value.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
kwikfishron (05-16-2012)
Old 05-16-2012, 07:27 PM   #12
i'm still not sure if i should keep subbing or installing
Old 05-16-2012, 07:29 PM   #13
Call your supplier and please read the journal of light conatruction as well as the other magazines i recommended. You should really be up to date on this, since you say your in the biz. Remember this site is DIY chatroom
Old 05-16-2012, 07:32 PM   #14
Framing Contractor
Rewards Points: 120
So JLC has info that the manufacturer doesn't?
Old 05-16-2012, 07:33 PM   #15
You should start selling to that way.
Drill a clean 4" hole in the exterior wall - wood and vinyl siding dym1944 Building & Construction 15 03-16-2012 01:56 PM
Vinyl Siding Sloping Wall swiederin Building & Construction 1 10-11-2011 03:08 PM
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 06:46 AM
how to install vinyl siding over curved wall? charliefoo Building & Construction 4 01-31-2010 09:25 PM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 10:13 AM
