Outside Tile Decks Over Membrain Leaking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2013, 12:42 PM   #1
outside tile decks over membrain leaking
have outside tile deck over rubberized membrain ia still leaking into grage below it takes about two years but then starts leaking again help.
BROWNS is offline   Reply With Quote
Old 01-20-2013, 01:03 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I don't have an answer for you, but I suggest you add a pic and list your location. I'm sure this information will help whoever is knowledgeable in this area.
Old 01-20-2013, 09:27 PM   #3
Rewards Points: 788
If you mean you had identified the leak, repaired it, and same spot is leaking again two years later, then I would suspect the spot and the repair. Did you remove the tile, repair the roofing, then reinstall the tile? I did not know that you can tile over the membrane which usually goes over a wood structure. Any wood structure outside is not stable enough for tile. Maybe the grout or thinset is abrading the membrane.
carpdad is offline   Reply With Quote
Old 01-21-2013, 04:29 AM   #4
Rewards Points: 4,734
1 can place tile over membrane but not directly,,, whoever did this neither knew a proper method NOR realized it would fail,,, certainly hope it weren't vous hate to face my bride, nagzilla, & confess it were me whodunnit
Old 01-21-2013, 10:35 AM   #5
Roofmaster
Rewards Points: 2,210
Yes you can do it but we have to have more information.
Support structure, deck type tile type, type of drainage etc. I am an expert in this type of design and can help but need more info.
Also, what exact type of material is your existing membrane?
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
leaking porcelain tile john77 Tiling, ceramics, marble 9 12-24-2010 04:45 PM
Shower leaking need to re tile Ineedhelp2009 Flooring 199 02-23-2010 05:46 PM
Tile shower pan leaking Daniel048225 Building & Construction 2 10-15-2009 02:18 PM
