-   -   outside tile decks over membrain leaking (http://www.diychatroom.com/f19/outside-tile-decks-over-membrain-leaking-169624/)
BROWNS 01-20-2013 01:42 PM
have outside tile deck over rubberized membrain ia still leaking into grage below it takes about two years but then starts leaking again help.
Blondesense 01-20-2013 02:03 PM
I don't have an answer for you, but I suggest you add a pic and list your location. I'm sure this information will help whoever is knowledgeable in this area.
carpdad 01-20-2013 10:27 PM
If you mean you had identified the leak, repaired it, and same spot is leaking again two years later, then I would suspect the spot and the repair. Did you remove the tile, repair the roofing, then reinstall the tile? I did not know that you can tile over the membrane which usually goes over a wood structure. Any wood structure outside is not stable enough for tile. Maybe the grout or thinset is abrading the membrane.
stadry 01-21-2013 05:29 AM
1 can place tile over membrane but not directly,,, whoever did this neither knew a proper method NOR realized it would fail,,, certainly hope it weren't vous :no: hate to face my bride, nagzilla, & confess it were me whodunnit :furious:
jagans 01-21-2013 11:35 AM
Yes you can do it but we have to have more information.
Support structure, deck type tile type, type of drainage etc. I am an expert in this type of design and can help but need more info.
Also, what exact type of material is your existing membrane?
