Outside Ideas For House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 07:11 AM   #1
Rewards Points: 190
outside ideas for house
Hello. I remodeled the first floor of the house entirely. I still have the basement and outside to do. The picture is the front of the house. I need some ideas. It needs major work and curb appeal. Removed two large tree in the front that were covering the entire house last year. Will post back of the house later.
ryanb4614 is offline   Reply With Quote
Old 02-28-2013, 09:04 AM   #2
Rewards Points: 150
Curb appeal I'd great but u have to like it it's your house I would look at pictures get an idea of what h wsnt and see if plausible
kaschmid3 is offline   Reply With Quote
Old 02-28-2013, 10:01 AM   #3
"You can do anything"-Mom
brockmiera's Avatar
For my personal taste, those older metal window / door canopies have to go. Paint the shudders white to match the rest of the trim work. Paint the front door.
brockmiera is offline   Reply With Quote
The Following User Says Thank You to brockmiera For This Useful Post:
Dave Sal (03-01-2013)
Old 02-28-2013, 10:56 AM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
It needs some color, perhaps a rose bush or something of that nature. Rip out that shrubbery you have now and go for a big flower bed right in front.
Maybe also some bushes or something lining the yard right next to the driveway.
Mort is online now   Reply With Quote
Old 02-28-2013, 11:05 AM   #5
Rewards Points: 150
I would get rid of bushes and aluminum awnings and shutters. What kind of siding is that ( aluminum asbestos wood? Maybe of do some vinyl raised panels on bay window reside even if just the front or done paint
Old 02-28-2013, 11:10 AM   #6
brockmiera's Avatar
you could move those hedges out closer to the street / sidewalk. then make a path from your front door to the street / sidewalk with an opening in the hedges. Maybe a nice arched arbor with flowering vines.
Old 02-28-2013, 11:14 AM   #7
brockmiera's Avatar
Just a thought
Old 02-28-2013, 11:16 AM   #8
A sheltered front door is functional - I'd keep it. I don't think I'd want my front yard to look very different from the others on the street. If everyone to both sides of you have nothing but grass then I'd go easy on the embellishments.
Dorado is offline   Reply With Quote
Old 02-28-2013, 11:26 AM   #9
Rewards Points: 190
Thank you for all the replies. Great ideas. The awnings will be coming off. I am putting new windows in after winter. Also would like to widen the driveway so we can have one car parked in the garage and be able to pull out. I am also thinking of possibly adding a gable roof over the front.
The bow/bay Window I am confused about. Inside I can walk under the opening. There is no ledge inside. It may just be a picture Window with two one the side?
Old 02-28-2013, 11:38 AM   #10
Rewards Points: 150
It's most likely one window with cables holding together on inside
Old 03-01-2013, 06:44 AM   #11
Rewards Points: 190
That's what I figured I can see any screws or anything. So is this a bay or a bow? On the outside they have an ugly tat roof over this Window. I will have to have a professional install this one. I had the windows in the back of the house replaced by a company. And they capped the outside. Very disappointed of how it looks. The caulked all around the capping into the brick and just looks sloppy the white caulking into the brick. Not sure if I can remove it. I installed one Window on the side and I have to cap it any suggestions capping with brick?
Old 03-01-2013, 06:50 AM   #12
Rewards Points: 150
Bay. A bow is made of 4 or 5 of same size windows more of a circle
Old 03-01-2013, 12:01 PM   #13
Rewards Points: 150
Either caulk or u have to grind out notch in mortar line for flashing and re mortar it
Old 03-01-2013, 10:36 PM   #14
Dave Sal's Avatar
Rewards Points: 728
Agree with the others about losing the awning over the door. But it would probably appear barren and stark, so perhaps a nice replacement would be in order. Matching copper lights, or wrought iron, on either side of the door would pull the look together nicely as well.
outside ideas for house-copperawnings.bg12.jpg   outside ideas for house-ol9905_loc_05ghi_sharp.jpg
Dave Sal is offline   Reply With Quote
Old 03-02-2013, 07:52 AM   #15
Rewards Points: 236
i seen a house where they added one of these(wth is it called ?) to the front of the house. it made a NICE difference.
http://www.thehouseplansite.com/wp-c...64/mas1019.jpg
Fix'n it is offline   Reply With Quote
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 09:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 06:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 08:07 AM
Garage shelving ideas koodawg General DIY Discussions 3 12-31-2010 09:52 AM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 08:36 PM
