Outside Dog Kennel Covers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 10:39 PM   #1
Unhappy
Got into helping out find ways to put a roof, low cost over 22 kennels that are chain link standing six feet high..side by side.
It is for local dog shelter,to keep dogs protected from sun,snow wind and rain.
I was thinking of 2x10 wood frame with roof of some sort to create a pitch
of at least six inches higher spot for weather runoff, rain or snow thaw.
Any ideas how to accomplish?
Norm
Norman Schultz is offline   Reply With Quote
Old 01-28-2012, 10:45 PM   #2
Rewards Points: 14,306
Build one long shed roof pole barn and move the kennels under it.
Cheaper then building all those smaller ones and less labor.
Use 5 Vee metal roof for a fast easy roof.
gregzoll (01-29-2012)
Old 01-28-2012, 10:48 PM   #3
http://www.agf.gov.bc.ca/resmgmt/pub...uct/373-09.pdf
Old 01-28-2012, 10:54 PM   #4
Rewards Points: 1,092
joe may be right, depending on the size of kennels, etc. my "kennel" is only about 6' wide, so i ran 2x4's across the top, plywood, and a gray/brown tarp (the blue tarps leak in no time). fast, cheap, simple, but ugly as sin. now and then, i go out and scrape most of the snow off. 2x10's? good god, how wide are those kennels?
Old 01-28-2012, 11:07 PM   #5
Wow, quick replies !!!
Pole Barn idea will be looked at for sure. I know 2x10 pretty hefty but I was looking for the pitch concept being a back-yard building hacker before turning it over to the pros. Hard to explain. Thank you…all you guys!
Old 01-29-2012, 12:07 AM   #6
There's no mention of where you live, in some areas there a need to heat and A/C or you can get in trouble.
Old 01-29-2012, 01:15 AM   #7
joe: good point. at 40 below, i don't even think of those things. ahhhh, for the need for AC now and then....
Old 01-29-2012, 05:16 PM   #8
Msradell's Avatar
Rewards Points: 338
I would certainly use corrugated metal for the roof. It's quite inexpensive and very durable in the long run.
Msradell is offline   Reply With Quote
Lambskin vs. Synthetic roller covers m1951mm Painting 4 08-12-2011 03:34 PM
Gutter covers, good or bad jeweler Roofing/Siding 2 03-04-2010 12:39 PM
Pavers in kennel seanhotrod Landscaping & Lawn Care 2 10-14-2009 12:59 PM
album covers "tiled" on a concrete floor? is it possible? brian williams Flooring 3 06-08-2009 09:43 AM
Magazine covers as wallpaper-HELP memo General DIY Discussions 4 10-06-2008 08:07 PM
