Outside Corners For Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 10:05 AM   #1
outside corners for vinyl siding
how do you join 2 outside corners for a 2 story addition
clatwil is offline   Reply With Quote
Old 05-05-2013, 10:21 AM   #2
kwikfishron's Avatar
Rewards Points: 178
I make two 45 degree cuts on the lower corner with the long point on the outside, then slide the upper corner over that.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
MelissaR (05-06-2013)
Old 05-07-2013, 07:39 AM   #3
That's how it is done.
nightriderrv is offline   Reply With Quote
How to Nail New Siding Under Existing Siding Shuriko Building & Construction 25 05-21-2012 09:33 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
