Outside Baluster Spacing - Building & Construction - Page 4 - DIY Chatroom Home Improvement Forum
Old 08-04-2008, 05:43 PM   #46
the Musigician
DangerMouse's Avatar
Question
brass globes
i found these thick, brass globes i might be able to work in. wood stained now too, looks nicer. note doggie in the window. she's our newest throwaway. just got her spayed and finished her shots.
(she's a shepski lol) =o) thank you for all your help and advise. maybe when i'm done with this place i'll post a whole set of pics!
DM
Old 08-04-2008, 05:50 PM   #47
the Musigician
i can fill them with concrete and sink a lag screw in them! they'd be locked down then! =o) i also will be adding a support triangle under the handrail at the newel post and lag them together tighter. then the 3" or so handrail bottoms. what do you guys think so far?
DM
Old 08-06-2008, 03:00 PM   #48
Another DIY Zombie
Rewards Points: 264
What is the framing made of? Are you going to paint it to blend in with the new railing? Looks nice!
javan is offline   Reply With Quote
Old 08-06-2008, 03:44 PM   #49
the Musigician
framed in 2x6 treated, i plan on 'hiding' them with the stair tread scraps. thanks! still trying to figure out a unique way to cap the posts.....
DM
Old 08-07-2008, 07:24 AM   #50
Another DIY Zombie
Rewards Points: 264
How about a cladding them in copper?
Old 08-07-2008, 07:45 AM   #51
the Musigician
interesting... hmmm... but i already ripped out the side trim to cover the seams on the newels....
DM
Old 08-10-2008, 07:51 PM   #52
the Musigician
Smile
the end result
the brass globes seemed to create moisture underneath, so no to them. this is what i ended up doing. hope y'all like it. thanks for the ideas!
DM
Old 08-10-2008, 08:36 PM   #53
Registered User
Termite's Avatar
Fancy schmancy! I like 'em.
Old 08-11-2008, 06:54 AM   #54
the Musigician
tnkx KC.... the wife says they look like arab turbans,,,,lol i just used the handrail scraps for the tops and sliced them up the middle for the bottom moulding. worked out well i think.
DM
Old 08-11-2008, 06:57 AM   #55
the Musigician
today i will finish up completely i hope. tread faces and 2x6 frame 'hiding'. will show my work here when done.
again, thanks to all who helped with ideas and needed code info. =o)
DM
Old 08-11-2008, 10:16 PM   #56
Extreme DIY'r Adk's, NY
Rewards Points: 272
what kind of wood and finish is that?
I had a cedar deck on a house that looked similar. It was finished with Sikkens stain that was like friggin black ice in the winter... absolutely unwalkable! I tore it apart, flipped the boards, planed them and reinstalled one weekend. Ended up staining it forest green, lol
crecore is offline   Reply With Quote
Old 08-12-2008, 07:43 AM   #57
the Musigician
crecore, the wood is australian jarrah and brazilian walnut (recycled), natural stain, and yes, it will be slippery as heck in winter. lucky for us it's the back yard and will not be used in winter much if at all.
DM
Old 01-13-2009, 01:48 PM   #58
Rewards Points: 372
Did you use the brass globes for the top of the posts? I couldn't see it in the last picture. That's a good way to use the rest of the handrail.
gma2rjc is offline   Reply With Quote
Old 01-13-2009, 01:59 PM   #59
the Musigician
the brass globes seemed to create moisture underneath, so no to them. (post #52)
DM
Old 01-19-2009, 05:23 PM   #60
Rewards Points: 372
What kind of finish did you use and is it holding up pretty well to the sub-zero temps?
Conduit Spacing / Separation smitty286 Electrical 3 04-08-2008 11:11 AM
Baluster Spacing chicago woodman Remodeling 4 12-08-2007 12:19 PM
Sonotube spacing billinak Building & Construction 2 05-03-2007 05:31 PM
Baluster Centers ?? sootybuttercup Carpentry 3 05-02-2007 09:36 PM
spindle spacing jibber Carpentry 5 02-18-2007 09:30 PM
