Old 07-30-2012, 07:22 PM   #1
Outer felt wallboard has a hole in it.
Does anybody know how to fill a hole in the exterior felt wall board that I think a bird made. Last winter I had a bad windy day and some of my siding fell and I have not got around to fixing it yet. Now I have a hole int he felt borad and need to fix the hole.
jerry1967 is offline   Reply With Quote
Old 07-30-2012, 07:58 PM   #2
Cut a pice of foam to fit. (adjust the hole to make this easier) and put the blasted siding back up!
Evstarr is offline   Reply With Quote
Old 07-30-2012, 08:12 PM   #3
Felt board? Sure it's not Celotex?
Post a picture.
Far cheaper to buy a new piece of Celotex, cut it to fit so it can be nailed in the middle of the studs then to use foam.
Old 07-30-2012, 08:50 PM   #4
Post a picture.
Yes it is Celotex, I couldn't think of the name.
The whole is only 2 inches in diameter,so is there a better way to fix this than to put a whole board up?
Old 07-30-2012, 08:56 PM   #5
You do not to replace the whole board, your just stuck having to buy a whole panel.
Just think how simple this would be if you would have of fixed it before there was a hole.
Old 07-31-2012, 12:09 PM   #6
Ok, can you give me a idea how to fix it once I buy the board?
Old 07-31-2012, 12:37 PM   #7
Remove the siding in that area, cut out a square with the two outer edges cut over the middle of the studs.
Cut a patch the same size as the hole and nail it up with 1-1/4 roofing nails.
Tape over the seams and reinstall the siding.
Old 07-31-2012, 01:21 PM   #8
tony.g is offline   Reply With Quote
The Following User Says Thank You to tony.g For This Useful Post:
Evstarr (08-03-2012)
Old 08-01-2012, 07:57 AM   #9
thanks for the information, what kind of tape should I use?
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General Discussion 14 02-28-2010 11:04 PM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General Discussion 2 01-01-2010 11:06 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
