#1 |
Outdoor wood storage cabinet/shed
I would like to build a wood cabinet outdoors to hold a weed eater, blower, shovels, rake, garden tools, a bunch of hurricane panels, some shelves up top for pots, and other assorted items.
Basically serving the same purpose as something like this: http://www.walmart.com/ip/Sterilite-...428501/8206253 Although I would like a vertical partition for taller things. The footprint is a concrete slab of 48" x 48" x 6" Deep The cabinet will up up against an existing exterior concrete block wall, so I can drill and attach PT lumber to it. It will be under the overhang portion of the roof, so it cannot go higher then 7 feet. I am trying to figure out how to build it. Do I just build it like how you would build an interior wall, basically have a bottom plate, a top plate, with studs spaced say 16" apart all using PT 2x lumber. That makes the back, left and right sides of the cabinet, and attach the back side to the concrete block wall. Use PT plywood to finish the exterior left and right side, as well as make front doors out of it. Something along that line? Or there are existing plans for a better job? |
#2 |
Something like this, but using the existing wall for the back?
http://www.hometips.com/diy-how-to/l...hed-build.html |
| The Following User Says Thank You to 7echo For This Useful Post: | miamicuse (07-28-2012) |
#3 |
Yes, this is pretty close.
Now I don't need a roof, as it will be under the eave so I am just going to make a flat top and cover with a piece of marine grade plywood. |
#4 |
Slope the top, if you get any rain at all.
Also if you get any rain at all put a floor in it so rain does not come in. Seal your bottom plate to the concrete. |
#5 |
Never have the roof be perfectly flat, and just plywood of any type will delaminate and rot over time. Far better to shingle it and build it with at least a 4-12 pitch.
No one has ever built a storage area to big, if you going to do it make it bigger then you think it needs to be. Far cheaper to have more then enough room then to have to add on once it's done. |
#6 | |
Outdoor wood storage cabinet/shedQuote:
However, there might be an argument made to just build it all the way to the soffit and use that as the "ceiling". |
| The Following User Says Thank You to miamicuse For This Useful Post: | mae-ling (07-28-2012) |
#7 |
If you'd only be 6" below that may not be a bad idea.
#8 |
Build it all the way up because a 6’’ gap will make a nice nesting spot, then you will have another problem.
| The Following User Says Thank You to epson For This Useful Post: | miamicuse (07-29-2012) |
#9 |
AHH, SPANS!!!
Build all the way to the overhang and that covers your roof situation. Build it just like standard walls, with top plate, treated bottom plate and a header for the door. I would recommend using the hardie t1- 11 for the siding as it will withstand weather for an increased time period and not de laminate like plywood. For the walls build the wall framing out to the edge of the slab and hang the siding an inch down below the bottom of the bottom plate down onto the slab to keep water from traveling back onto the slab. Use pressure treated lumber against the concrete block wall. You can also make a door out of the hardie t1-11, a 1x4 or 2x4 X frame will help to strengthen the door and keep it solid with no warping. A cheap skil saw blade will cut the hardie or get one of the blades they make for hardie, good luck!
| The Following User Says Thank You to hand drive For This Useful Post: | miamicuse (07-29-2012) |
#10 |
Outdoor wood storage cabinet/shed |
#11 | |
#12 |
A slight complication. The eave is not level but slopes downwards, so the top plate of the side walls will need to be inclined?
I would rather not have to miter each individual stud to fit. May be I can still make the walls straight and level, but cut the T1-11 siding on a slope to reach the eave? |
#13 | |
AHH, SPANS!!!
#14 |
wood hobbyist
Not sure if you finally found what you are looking for but here is another on to check out, comes with a video. Its one I'm looking at doing on the back of my pool house. I simply went to google, typed in "lean to shed family handyman". There is a quickcrete ad first then the video its 23 minutes long but put together really well. Good luck and update some pictures with your progress.
#15 |
Much appreciated !
| Display Modes | |
| Out of room..Need a storage shed!!! | Gomezy3k | Building & Construction | 6 | 12-19-2011 11:27 AM |
| Crawl Space into Mini Storage Room | Mikef5000 | Building & Construction | 2 | 03-01-2011 07:01 PM |
| Adding storage to window seat | apruden | Carpentry | 2 | 11-06-2009 05:54 PM |
| attic storage | storageseeker | Building & Construction | 2 | 01-29-2009 09:02 AM |
| Attic storage - construction type? | rt4me | Building & Construction | 4 | 01-01-2009 05:33 PM |
