Outdoor Hot Tub...Is Pouring Cement Base A Diy Project? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2007, 05:46 PM   #1
Outdoor hot tub...Is pouring cement base a diy project?
The hot tub "pad" needed will be 6'x6'...The soil is soft...What steps do I take, dig a 6'x6' by 3" deep trench? Rent a ground compactor to compact the soft soil? Then pour and smooth out the cement? Anyone have any tips on what type of cement/concrete I should use and how long I should let it dry before I put the tub on the slab? I'm guessing the filled hot tub will be 5000 with water...I'm in GA, hot and humid this time of year...
Bacardi 151 is offline   Reply With Quote
Old 05-11-2007, 06:41 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Check this out:
http://www.ezpads.com/advantages.htm
http://www.ezpads.com/more_info.htm
- Build Well -
Old 05-12-2007, 07:31 AM   #3
Originally Posted by AtlanticWBConst. View Post
Thanks, awesome info! I never realized those thing existed. I can't seem to find a dealer of those that list their price. I also can't seem to find info if they're ok to put on soft soil. I can find simular pads on ebay, for the size I need they are just shy of $400. Seems to be a shovel, ground compacting machine rental (which I might need for the pads anyway) and several bags of cement would 75% cheaper than those pads...
Old 05-12-2007, 08:43 AM   #4
Rewards Points: 340
I built a ground level Deck - 8x8
It sits on 6 cement footers, drilled 36 to 42 inches. I used tubes to help me level the frame.
7 years and still going.
IF you use the pads - I think it would settle quite a bit. You would have to make sure the soil is compacted.
tribe_fan is offline   Reply With Quote
Old 05-12-2007, 11:04 AM   #5
Thanks for your input. I thought about this as well as you don't need a compactor. I wasn't sure how to reinforce the deck though to support the weight of the hot tub though. I still wonder if the cement would be cheaper...
Edit. Anyone have any input with digging, not compacting and just putting down cinderblocks?
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
