Outdoor Fireplace Stone Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 07:09 PM   #1
outdoor fireplace stone installation
We have a used heatilator that we want to turn into an outdoor fireplace. We want to install cultured stone to the metal exterior. Can this work and can we do it with regular exterior thinset, if not, suggestions please?
sylvia51 is offline   Reply With Quote
Old 08-12-2011, 10:31 PM   #2
Rewards Points: 5,336
Contact the manufacturer as to the advisability of moving this unit to the exterior.
Ron
B. Franklin 1759
Old 08-14-2011, 04:56 PM   #3
Concrete & Masonry
Rewards Points: 576
Not a good idea for a number of reasons, with the two major ones being:
- The steel expands/contracts a great amount when it heats & subsequently cools back down. The stone will not last much longer than a fire or two.
- The stone will get so hot, they will be dangerous to be near.
The safer approach is to build a concrete block surround around all sides of it first, and apply the stone veneer to this. Even this approach takes a little background though. Try searching for a install manual for a "heatilator", "vestal-air", "hutch", etc..... I think you should be able to find one online to give you a good idea how it can be done safely.
jomama45 is offline   Reply With Quote
Old 08-15-2011, 09:58 AM   #4
Thank you so much for your advice. We will do some more research.
Old 08-15-2011, 12:14 PM   #5
Rewards Points: 1,232
It has to be wrapped with masonry on the exterior, but the most important fact is that it won't last long outside. Hot metal rusts quickly.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 04:58 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
