Outdoor Brick Fireplace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 02:58 PM   #1
Rewards Points: 254
Im planning on making a brick fireplace for the backyard. I found a wood burning fireplace insert that was from a house and plan to use that as the fire box. I plan to enclose the insert with brick on the sides and back but where I am stumped is how should I make the transition from the top of the insert to the chimney? I know I cant rely on the insert to hold the weight of the bricks as I stack them for the chimney.
I posted a pic and have the area in question in red.
pwgsx is offline   Reply With Quote
Old 12-01-2011, 03:18 PM   #2
Rewards Points: 12,790
Very poor plan, the steel with just rust out in a few years and you would need the brick to be laid over a steel plate to keep it from crushing the insert.
Old 12-01-2011, 03:24 PM   #3
Rewards Points: 254
are you saying the steel plate would rust? or the fireplace insert?
Old 12-01-2011, 03:25 PM   #4
Insert
Old 12-01-2011, 03:27 PM   #5
Rewards Points: 254
i dont know, its been outside for a few years from the guy i got it from and in my backyard all summer, im not seeing any rust. The one in the pic is not mine btw.
Old 12-01-2011, 07:15 PM   #6
Concrete & Masonry
Rewards Points: 468
The best way to do it IMO, and from previous experience with Vestals, Dutch, etc... fireplaces is to simply pour a re-inforced concrete "shelf" near the top of the unit where you'll transition to flue liner. The only weight the concrete should really need to support will be the flues & a small amount of block/brick around the flues, as most of the weight should be transfered to the exterior shell via corbelling.
jomama45 is offline   Reply With Quote
Old 12-02-2011, 10:43 AM   #7
Rewards Points: 254
I like that idea. Do you happen to have any pics of the shelf form going together or pics after its poured? Thanks for the help!
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
