Out Of Square Deck - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 07:27 PM   #16
Originally Posted by Jay bird View Post
My measurements on my deck are all the same except my diagonal any ideas
Originally Posted by no1hustler View Post
Split the difference. Using Pythagorean theorem, you should be able to find out what the correct measurement should be.
How is he going to split the difference which would make it square if an "equal" measurement is obtained in the out of square side(s)
Well why not give ( Jay) the actual numbers from that Roman Gift and not make him hunt
Jay, the magic numbers are 3.4.5 or 6,8,10, applied as such
Measure 3 feet one way. 4 feet the other way and from those two points it should be 5 feet across. Or, change to 6,8,10. You can use these numbers in 10 increments such as 3.4.5 in inches or 20 feet 40 feet and 5- feet at the 45 angel from those two points
21boat is offline   Reply With Quote
Old 06-01-2012, 08:11 PM   #17
GBrackins's Avatar
Rewards Points: 2,108
Originally Posted by GBrackins View Post
Jay, if you got to this link and enter the two side it will give you the diagonal
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-01-2012, 11:21 PM   #18
So whats that going to do.???
As a builder. I looked at your posted web, and I never had an instance laying out a foundation for a structure where 3,4,5, or 6,8,10, never worked. Even if its a very small area since an increment of 10 can be applied to each group of the three numbers.
The issue I had with the posted site was that site didn't even mention the 6,8,10, availability which mathematically covers another ljob situation.
BUT, you still have to cross measure to check that square. Hows that work with this calculator to check the Side 3 Length (hypotenuse) when again you have to cross measure and obviously you have room or MUST have room to cross measure,
Also this site never mentioned ALL measurement has to be on a level plane or level in slope with one side level and the adjacent sides equally sloped together to be accurate.
So how could this calc actually be any good at this point. Knowing that last distance and not being able to check it by physically measuring that 45 degree.
Then it talks about how good it is for concrete forms. In my world that's when 345 6810 is the easiest in flat work because Nothing is in the way.
I've seen a lot of sites that misleads the laymen but this so far take the cake by not explaining you STILL have to physically cross measure on a level plane. If you can do that then obviously have to know where one corner is and the other side wall is to cross measure, so whats the point of this Site???
Old 06-02-2012, 01:35 AM   #19
GBrackins's Avatar
21boat,
I don't know if all of your previous rant was directed at me and the link I provided since you "quoted it", or if you were going off on someone else. To answer your question "So whats that going to do.???" What this does is provide someone the diagonal distance when they enter the two sides of a right triangle, in the same manner as 5 provides the diagonal dimension of the right triangle with a side of 3 and another of 4. Or 7.5 as the diagonal of a right triangle when one side is 4.5 and the other is 6.
My post was addressed to Jay the OP, whom was had laid out a deck and wanted to know how to figure the diagonal dimensions for his deck. He did not provide the measurements of the sides or I would have calculated the diagonal dimension for him. In case he was not well versed in geometry I provided him a simple tool to get his answer. I didn't have a photo of his deck, but would believe he could measure from one corner diagonally to the other since this was a deck.
This would provide him the answer to his question .... how does your comments provide him with the answer he was seeking?
Now that I think of it, but correct me if I am wrong, but the 3,4,5 method also requires measuring the diagonal does it not? And the 3,4,5 method does not provide a 45 degree angle, it provides one 90 degree angle, one 36.87 degree angle, and one 53.13 degree angle. If one need a 45 degree angle use 10 for the sides and 14.14 for the diagonal.
Gary
Old 06-02-2012, 09:13 PM   #20
Old School
Willie T's Avatar
Gary,
I can't believe someone would ask you such a question. Do they really think you have to have a connecting third line to get the two ends square? Kind of scares me to imagine them working on a project.
Willie T
Old 06-09-2012, 09:50 AM   #21
Rewards Points: 282
correct, a^2+b^2=c^2 for any right triangle with c = the long side (i wont say hypotenuse, apparently that causes wars, lol).
using the 3,4,5 example we know the 5 = c (the long side)
3^2 (9) + 4^2 (16) = 5^2 (25)
to make a 45 degree angle 10^2 (100) + 10^2 (100) = 14.14^2 (200)
To get really giggy, its fun to read the roofing forums, those guys hold advanced degrees in trig but dont even know it!
jcrack_corn is offline   Reply With Quote
Old 06-09-2012, 01:26 PM   #22
GBrackins's Avatar
People can easily perform calculus and trig, as long as you don't tell them they are doing calculus or trig. Some people consider math to be a four-lettered word.
Good comments jcrack!
Gary
Old 06-09-2012, 02:52 PM   #23
What was your expected diagonal length?
Deck Support Beam temporary fix. george747 Building & Construction 5 10-17-2011 09:41 PM
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 12:55 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 01:57 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
