Out Of Square Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 09:34 PM   #1
Out of square deck
My measurements on my deck are all the same except my diagonal any ideas
Jay bird is offline   Reply With Quote
Old 05-30-2012, 09:43 PM   #2
Old School
Willie T's Avatar
You're kidding, right? "Rack" it some till you no longer have a parallelgram, and the two diagonals read the same. (Shove the corner of the longest measurement toward the shortest.)
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Jay bird (05-30-2012)
Old 05-30-2012, 09:45 PM   #3
How far are you out?
Old 05-30-2012, 09:47 PM   #4
I have post set joist will be resting on a beam .Could I rack it on the beam ?
Old 05-30-2012, 09:49 PM   #5
Four inches
Old 05-31-2012, 07:43 AM   #6
Custom User Title
Rewards Points: 252
Split the difference. Using Pythagorean theorem, you should be able to find out what the correct measurement should be.
no1hustler is offline   Reply With Quote
Old 05-31-2012, 08:53 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
I've always found to make one side as a designated straight side( usually the house side) and then try and square everything off that side. temporary bracing helps as a save the day approach to fully racking a deck to square
hand drive is offline   Reply With Quote
Old 05-31-2012, 09:29 AM   #8
GBrackins's Avatar
Rewards Points: 2,108
Jay,
try this .... http://www.construction-resource.com...uare-forms.php
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-31-2012, 11:22 AM   #9
Newbie Bill
Rewards Points: 522
I can attest to the challenges of trying to square the whole deck. I needed to move the beam/post end of my 10' by 19' deck a 1/4 inch to square it up. Took me half an hour doing it by myself.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-31-2012, 01:06 PM   #10
AHH, SPANS!!!
when working on deck/framing I am always 2 steps away from a 2x4 to use as a pry board to move something heavy around if needed. I worked with a guy who always nailed 2xs onto something and then pivoted off of the nails to raise/move stuff. there were constantly nails to be pulled/cut sticking out of stuff where he yanked the pivot board off and the nails stayed
Old 05-31-2012, 03:22 PM   #11
Rewards Points: 282
why?
unless you built it out of welded steel/iron, it will move/expand/contract unevenly (especially within the first year).
welders get things square, carpenters get things close.
jcrack_corn is offline   Reply With Quote
Old 05-31-2012, 08:58 PM   #12
CrossWorks's Avatar
Rewards Points: 150
Originally Posted by jcrack_corn View Post
why?
Not this Carpenter!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 06-01-2012, 09:41 AM   #13
why?
Where did you get that from? I can assure you everything I have ever bilt is as square as the day I framed it.
RYANINMICHIGAN is offline   Reply With Quote
Old 06-01-2012, 09:50 AM   #14
Newbie Bill
Rewards Points: 522
I remember my brothers and brother-laws built a cabin in the mid 80's. We spent a lot of time getting the sill plate square. The running joke is that cabin is the squarest structure in the county.
Bill
Old 06-01-2012, 11:25 AM   #15
Old School
Willie T's Avatar
NO! You never build anything on something that is not flat, level, and/or square (if it is supposed to be) and hope to make it right later by shifting something built upon the defective base.
Do each step correctly BEFORE moving on to the next one.
Willie T
mae-ling (06-01-2012)
Deck Support Beam temporary fix. george747 Building & Construction 5 10-17-2011 09:41 PM
tiling deck of a 5 ft corner tub level with tub deck Blue Falcon Carpentry 16 09-28-2011 12:55 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 01:57 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
